pascalachermann Posted August 15 Share Posted August 15 Hi Everyone Becuase we encountered a problem where almost every Symbold that has been modelled in Vectorworks has chaotic Facenormal directions. This turns into a problem once you use CAD Data in realtime such as VR & AR where we have only enough drawcall time for one face side to be drawn. I made a little script that will help us fix Normals on Faces, however this works only if we completely ungroup Symbols, but we can't do that because we lose all our Database connections. This is the script that works only on a ungrouped mesh: import vs def uniform_surface_normals(): # Get the handle to the first selected object on the active layer h = vs.FSActLayer() # Check if an object is selected if h is None: vs.AlrtDialog('No object selected!') return num_faces = vs.GetNumFaces(h) for i in range(i, num_face + 1): normalX, normalY, normalZ = vs.GetPolyFaceNormal(h, 1) vs.GetPolyFaceNormal(h, i, 0, 0, 1) vs.ReDraw() # Run the function uniform_surface_normals() it Would be amazing if you could help me doing this on selected Symbols, i was unable to get into the symbols with phyton. best regards Pascal Quote Link to comment
Pat Stanford Posted August 15 Share Posted August 15 vs.FInSymDef will get you the first object in the symbol. h = vs.FSActLayer() h = vs.FInSymDef(h) 1 Quote Link to comment
MullinRJ Posted August 16 Share Posted August 16 Hello, @pascalachermann. It would help a lot if you'd post a sample VW file that contained symbols that you were trying to process. Also, please include a symbol with before and after states so we can see what the answer should look like, even if you have to do it by hand. Guessing is not a good way to go when trying to solve someone else's problem. vs.GetPolyFaceNormal() and vs.GetPolyFaceNormal() are not a built-in VW functions, so you might want to post them, too. Thanks, Raymond 1 Quote Link to comment
MullinRJ Posted August 16 Share Posted August 16 Hello @pascalachermann, Are you using an extension for the VS commands? If so, most of us in the US will not be able to help you directly because we do not have the same extension. Please describe your setup in more detail. Thank you, Raymond 1 Quote Link to comment
pascalachermann Posted August 19 Author Share Posted August 19 Dear @MullinRJ Raymond we are using the internal Vectorworks Script Window, we use the native Code console where you make an inventory object aka the Script. I will post a symbol example in short. Thanks for your inputs and support! @Pat Stanford & @MullinRJ best regards Pascal Quote Link to comment
Pat Stanford Posted August 19 Share Posted August 19 @pascalachermann I see you are in Switzerland. It is like you are using the Computerworks German localized version. Computerworks does a great job and has added a substantial amount of content to VW, including some "extra" Vectorscript commands that don't exist in the US version that Raymond and I use. The added features include the FaceNormal functions. So while we can help with the structure and syntax of your script, we will not be able to run and test it. 😞 1 Quote Link to comment
pascalachermann Posted September 13 Author Share Posted September 13 @MullinRJ Now this Version should work, my client exported the symbol with a float license. best Regards Testsymbole V_01.vwx 1 Quote Link to comment
MullinRJ Posted September 14 Share Posted September 14 Hello @pascalachermann, I was able to open your new file. However, I still am not able to run your Python script to see what it does, because it contains unique calls that are only available to you on your VW installation, namely: vs.GetNumFaces() and vs.GetPolyFaceNormal(). I think your best bet is to find someone with the same VW installation to help you. If there is a way to post the workings of those two functions, then more people on this forum might be able to lend a hand. All the best, Raymond Quote Link to comment
pascalachermann Posted September 15 Author Share Posted September 15 Hi @MullinRJ thanks for trying, just to make sure, my functions are only working of you ungroup the symbol. they should then work. However that is my problem, im not supposed to ungroup them, becuase it breaks some connection to the database, according to my client. Ideally would be if this script can be enhanced to traverse inside the symbol and walk over ther vertices without having them to ungroup and open. 🙂 Quote Link to comment
Mirko Guhr Posted September 15 Share Posted September 15 hello @pascalachermann, i haven’t been here for long and I’m more focused on Marionette. I haven’t had much contact with the script files yet. It wasn’t easy to understand at first what Vectorworks is doing. The symbol objects in a drawing are of type 15, those in the library are of type 16. I think the script explains most of it. I tested it with classes. Attached you will also find my file where my tests and the “final” script are located. You will also notice that not all objects change. This is because they are in a groups. Additionally, the objects for the script must be in the first level of the resource manager. This can all be changed. It just increases the complexity, and I wanted to know from you first if it even works. It seemed to me that time was also a bit pressing. I didn’t know which version you are using. I’m on 2023, so I got a message and therefore exported to 2019. I’m not sure where vs.redraw() should go. I have too little experience with the syntax and normal-maps in Vectorworks, especially since I can’t debug due to the missing syntax from your tool. But whatever 😄: import vs def change_class_to_02(): # Get the first object on the active layer obj = vs.FActLayer() if obj == vs.Handle(0): vs.AlrtDialog("No objects found on the active layer.") return while obj != vs.Handle(0): # Get the type of the object obj_type = vs.GetTypeN(obj) # Check if the object is a symbol if obj_type == 15: # 15 represents a symbol # Get the linked source symbol symbol_name = vs.GetSymName(obj) # Search the library for the source symbol sym_def = vs.FSymDef() symbol_found = False while sym_def != vs.Handle(0): if vs.GetName(sym_def) == symbol_name and vs.GetTypeN(sym_def) == 16: # 16 represents a symbol definition symbol_found = True # Iterate through all objects in the symbol definition sym_def_obj = vs.FInSymDef(sym_def) if sym_def_obj == vs.Handle(0): vs.AlrtDialog(f"No sub-objects found in source symbol {vs.GetName(sym_def)}.") while sym_def_obj != vs.Handle(0): # ----------------pascalachermann-------------------------- num_faces = vs.GetNumFaces(h) for i in range(i, num_face + 1): normalX, normalY, normalZ = vs.GetPolyFaceNormal(h, 1) vs.GetPolyFaceNormal(h, i, 0, 0, 1) # ----------------pascalachermann-------------------------- vs.ReDraw() #<<<<<<< ????!!!!???? # ----------------pascalachermann-------------------------- sym_def_obj = vs.NextObj(sym_def_obj) break sym_def = vs.NextSymDef(sym_def) if not symbol_found: vs.AlrtDialog(f"Source symbol {symbol_name} not found in library.") # Move to the next object on the active layer obj = vs.NextObj(obj) vs.AlrtDialog("All objects have been processed.") # Execute the function change_class_to_02() I’m curious to see if you can make something out of this. Best regards TS V_01_Zuzzla_v2019.vwx 1 Quote Link to comment
Mirko Guhr Posted September 15 Share Posted September 15 What also occurred to me: Is it important to only edit the objects in the drawing/construction layer, or do you want to convert all the symbols in the file anyway? This might simplify things a bit. We could define a folder named “NumFaces”. When executed, the script will try to apply to all symbols in it. Or on the entire file, that would also be possible. Quote Link to comment
MullinRJ Posted September 15 Share Posted September 15 8 hours ago, pascalachermann said: Hi @MullinRJ thanks for trying, just to make sure, my functions are only working of you ungroup the symbol. they should then work. However that is my problem, im not supposed to ungroup them, becuase it breaks some connection to the database, according to my client. Ideally would be if this script can be enhanced to traverse inside the symbol and walk over ther vertices without having them to ungroup and open. Hello @pascalachermann, In theory, YES, you should be able to work inside a symbol definition. The problem I face concerns the two functions you use in your script that are not native to VW. Even if I guess how to structure your code, I cannot test it because it will not compile on my machine. I cannot even test the example that @Zuzzla posted, again because it uses the same two functions. Try his/her example and see if it works, then let us know how it went. All the best, Raymond 2 Quote Link to comment
