Load Combination Problem - Bridles between trusses or pipes creates House Rigging
Hi everyone,
I'm calculating a complex structure and I'm getting mad with this issue, its never happend before to me...
Each time that I try to insert a drop between two rigging objects and I try to calculate (all objects or load combinations) an house rigging appears and split the loads, so you are not able to transmit the weights from a system to another...
Does someone knows how to solve it?? I tried to modified bridle parameter but I did't get it working...
Thanks so much,
Sergio.
  • 3 months later...
So, after try thounsand of times and different paths I can't explain why is happening with my preferences on my computer.
I found a way that could solve the issue but it isn't really good solution.
If I insert a connection using Bridles parts, it doesn't matter if I chose "Bridle Part" or "Hoist" because it always is going to create a House rigging between the two objets breaking the weight structure. I tried to modify all the options and combinations into the bridle preferences, it doesn't matters.
My solution is insert hoist in the connection and select "Dead hang undefine" ( I even create a new symbol with different specs to do it faster) so it insert a chain between both objets with the load of 26kg... so you have to modify this weight most of the time because is unreal.
It looks like always create a basket on the top of my leg, so problaby it is the problem but I could reach the solution, I'm not sure.
There is a way to set to default the setting of the bridle preferences?
This is a screenshot with the comparison between bridle part and dead hang as a hoist.
Thanks and enjoy the easy and simple command "insert drop"... I'm really missing it!! hahaha
When you are using the insert connection to insert a bridle part based drop, try setting the bridle preferences to use the top leg with a length set to the size of a standard 3.25t shackle this will ensure that your deadhange bridle insert correctly and that your drop will calculate the parts correctly int he bridle configuration dialogue
  • 2 weeks later...
