Objects disappear when using SubtractSolid
This issue has been happening repeatedly for a while, and I'm looking for a way to solve it.   I build some complex models in Vectorscript, and sometimes use SubtractSolid to build some shapes.  A simple example code is:
<object code>
s1:=LNewObj;
<object code>
s2:=LNewObj;
subtract:=SubtractSolid(s1,s2,s3); DelObject(s1); DelObject(s2);
I've posted an example below.  Moving the object causes the parts to come back, but they eventually disappear again.  What is the best practice for making these objects stay?  Should I convert them to generic solids?  Do I need to reset the object in the code?
image.png.045b5b059d484d5edcffcdeb8e41d0a4.pngimage.png.dcf0e195af39989b918ce9b05b215583.png
Not sure but I do see this very occasionally when direct modelling and Convert to GS does the trick.
6 hours ago, Pat Stanford said:
Is this just a script or is this part of a PIO
Have you included a ResetObject call on the final subtraction in your script?
Have you included a Redraw/RedrawAll at the end of your script?
It is part of a PIO written in Vectorscript.   I do have a ResetObject(h) at the end, but I do not have a redraw.  The object does reset if I make any adjustment to it, but I'm wondering if the redraw would even happen if nothing triggers the plug-in to run again.  Might try the convert to generic solid.
