Mathijs van Ommen Posted July 25, 2024 Share Posted July 25, 2024 Hi, When I calculate the truss structure below, I get the message the static system could not be calculated. If I remove the lower part the calculation works. This can also be seen in the image below. Does anyone have an idea why this is happening? Regards Mathijs Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted July 25, 2024 Vectorworks, Inc Employee Share Posted July 25, 2024 BW gets finicky with vertical systems. Can you post a sample file? Quote Link to comment
Mathijs van Ommen Posted July 25, 2024 Author Share Posted July 25, 2024 TQ24-ST01-PDP.vwx Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted July 25, 2024 Vectorworks, Inc Employee Share Posted July 25, 2024 You had a few items that were not connected, and some of your hoists were not exactly centered on the truss. When you have items reported as not connected, use the "Select System Objects" in the OIP to find out which items are not connected, then shift them around a bit until they snap properly. Edit: I just noticed I connected one hoist to the bottom truss. Sorry about that. Once you move it back to the top, it should still work. TQ24-ST01-PDP-SCP.vwx Quote Link to comment
