Metric Pipe
Can someone direct me to a chart that has Metric Pipe (Stainless Steel)
Remember tubing and pipe are not the same thing.
Also are Metric Pipes based on imperial pipe?  Example DN 300 Pipe is (I'm told) is 304.8mm ID and 323.85mm OD.
I was really hoping to have a clean break from the imperial muck & have DN 300 Pipe be 300mm ID and 324mm OD or some clean state.
trying to build a library
thanks
This is the best chart I have found for comparison between ISO and ASTM pipe sizes.
As far are I know, the external diameter of pipe is the same in both ASTM and ISO systems and the actual diameter really does not have anything to do with the actual diameter of the pipe.  DIN pipe is different, but since the EU has come in, DIN is not as common as it used to be. All 2" pipe has the same OD. And 50mm ISO pipe has the same OD as 2" ASTM pipe.
Ask again if you need more help. I have been dealing with this for 30+ years.
https://vmsteel.com/wp-content/uploads/2020/04/wall_thickness_table.pdf
I pay the $20/month ChatGPT and have been pleased with the results.  But apparently the latest release of Llama this week is supposed to be even better if you don't mind sharing data with Meta/Zuckerberg.
Pipe is really weird because it does not match what it is called in any unit.
DIN was the German standard before Euro Integration. ISO is the now standard for metric.  The names are close to the real sizes, but much more challenging than tube which is actual OD size.
