WhoCanDo Posted July 18, 2024 Share Posted July 18, 2024 I just updated to SP6 I've lost my drag and drop. I can't drag vwx, dxf, pdf, dwg, etc. and drop them into my VW2024 SP6 Can you ? Additionally, when I Import a .pdf and ungroup it, after deleting the bmp and blackout page, there is no vector drawing left. Note: I am on a Windows 11 PC at the moment. Quote Link to comment
0 zoomer Posted July 18, 2024 Share Posted July 18, 2024 5 hours ago, WhoCanDo said: Additionally, when I Import a .pdf and ungroup it, after deleting the bmp and blackout page, there is no vector drawing left. Maybe because the PDf was rasterized and does not contain any vector data ? Or can you snap to the lines of that PDF ? Quote Link to comment
0 WhoCanDo Posted July 18, 2024 Author Share Posted July 18, 2024 I exported the PDF from my drawing before importing it again. Rasterize PDF was not ticked so it should have been vectorized. Quote Link to comment
0 WhoCanDo Posted July 19, 2024 Author Share Posted July 19, 2024 Another day. I tried the import and ungrouping. It worked today so not sure what happened after the update. However, I still can drag and drop any files after the SP6 update. This is a problem because I often drop multiple PDF, DWG & IFC files to open/import them. I'm not keen to update my other PC if it's going to be the same. However that is Windows 10 and this one is Windows 11 - which did work in SP5 Quote Link to comment
0 WhoCanDo Posted September 25, 2024 Author Share Posted September 25, 2024 Just in case someone else has a similar problem, the answer was fixed by the techs who told be to try disabling the default "Open as Administrator". Quote Link to comment
WhoCanDo
Can you ?
4 answers to this question
