Juha Tuomimaki Posted July 17, 2024 Share Posted July 17, 2024 Hi, I have inserted Marionette nodes into an existing Vectorworks document but for some reason they cannot be connected to each other. When I click the connection circle on a node, the connection line appears from the opposite side of the node and doesn't stick to any other nodes. This happens regardless of the node type. However, the problem does not occur on a blank document so there must be something different in my existing document that is causing this? Any idea what might be causing this? I have Vectorworks 2023 SP8 on Mac. Thanks! Quote Link to comment
Pat Stanford Posted July 17, 2024 Share Posted July 17, 2024 First step is to restart VW and reopen the file. If the problem persists, we will probably need to see the file to be able to diagnose the problem. Quote Link to comment
Juha Tuomimaki Posted July 17, 2024 Author Share Posted July 17, 2024 Thanks, Pat. Already tried restarting but it didn't make any difference. Unfortunately this is a client project which I am unable to share. Quote Link to comment
Pat Stanford Posted July 17, 2024 Share Posted July 17, 2024 Copy and Past the entire network into a different file and work on it there. Delete the one in the file with the problem (make a backup first). Copy/paste it back in and see if it helps. Or contact Technical Support directly. They are likely to have a way to help you with and NDA type support so you can let them see the file. If the NDA is truly that strict and it works in a different file, you may need to do a layer by layer copy to a new file. HTH Quote Link to comment
Antonio Landsberger Posted July 24, 2024 Share Posted July 24, 2024 On 7/17/2024 at 7:52 AM, Juha Tuomimaki said: Hi, I have inserted Marionette nodes into an existing Vectorworks document but for some reason they cannot be connected to each other. When I click the connection circle on a node, the connection line appears from the opposite side of the node and doesn't stick to any other nodes. This happens regardless of the node type. However, the problem does not occur on a blank document so there must be something different in my existing document that is causing this? Any idea what might be causing this? I have Vectorworks 2023 SP8 on Mac. Thanks! Hi @Juha Tuomimaki, Welcome to the Vectorworks forum and Marionette in particular. The behaviour of nodes and their connections you show and describe is definitely not normal or usual. In fact, I cannot remember ever having seen this with Marionette. And a quick search in the bug report system, reveals that this hasn't been reported either. Here's an image of what your situation should look like approximately: 0) Are you trying this in Top/Plan or a different view? 1) Does this happen in a new empty file as well? 2) Have you tried resetting your user folder? 3) Have you tried running the installation repair? Best regards, Antonio Quote Link to comment
