Plugin runs twice
Hi All,
Wondering if anyone can help with this question. If I make a linear plugin object then the script runs twice, and if I make a rectangular plugin object then the script runs 3 times. This is regardless of whether I have "developer mode" turned on or off.
The script is simply:
import vs
vs.AlrtDialog('test')
Does anyone know the solution? Thanks.
This is normal behavior for PIOs. I don't remember all the details, but we have discussed this before.
Basically, the script runs when the object is placed and then again when the object is reset. I am not certain what the third run for a rectangular PIO is.
I THINK that if you make an event enabled PIO (much, much more complicated) then you can catch the different events sent for the different runs and only run the parts of the script (including parts that have zero code) that need to be run at that time.
Sorry. HTH.
Thanks Pat.
I am currently writing a plugin where the user will draw a line or rectangle then, based on the dimensions of the line or rectangle, a dialogue box will appear with various checkbox options that the user can select. There will then be information placed on the drawing depending on what the user selects. I have achieved all of this, except that the dialogue box appears twice when the line is initially drawn. Do you know if there's a workaround for this? Thanks.
@michaelk has a script where he checks the time and if the script runs again within a certain number of seconds does something different (or doesn't do something, I can't remember).  You could do something like that.
Or maybe play with VSTGetEventResult and see if that gives different values on each run.
GetEvent might be what you want.
Take a look at this thread where michaelk asked almost the same questions a few years ago and @MullinRJ provided a good answer.
So if the event is the same, then something like Michaels time check might be the only solution.
Or modify the PIO so that it does not automatically open the dialog box and have the user make those settings in the OIP or via a dialog box opened by a button in the OIP. You could even add a "new" flag field so that the dialog box opens when the object is placed but then check and if it has already opened once then does not open again.
  • 1 year later...
Just ran into this issue, a (slightly) less botched solution seems to be checking:
vs.vsoGetEventInfo()
Which also provides an 'event data' int.
Here is a little test script:
import vs
_, outEventData = vs.vsoGetEventInfo()
vs.AlrtDialog(outEventData)
Hopefully you will get two different alerts
  • 1839945008 (The initial placed event)
  • 1839945888 (The secondary reset event)
Using this you can easily check for the initial object creation event:
import vs
placeEventId = 1839945008
def execute():
    if outEventData == placeEventId:
		# Take inital user inputs...
    else:
		# Update the object...
execute()
