- Using the active class menu holding a modifier key (cntrl/command or alt/option) could change the class visibility (make it a class visible/invisible toggle).
- The 2D Mirror tool should cast a doted ghost preview as the 2D Rotate tool does.
- The 2D Rotate tool should have a Rotate & Duplicate mode as the 2D Mirror tool does.
- The Flyover tool when on the 'Center of Selected Objects mode' should revert automatically to 'Center of Ground Plane Mode' if you try to use it when no object is select.
- There could be a preference to make the 3rd modes of fillet and chamfer tools the default ones.
- The new Layer and Class visibility panels should be resisable.(They could be non-modal ? is that the term ? ? that is, hang around like the Obj. Info Palette)
- Set 3D View instead of (or in addition to) Rotate 3D View for ViewPort view editing.
[ 07-14-2004, 08:14 PM: Message edited by: Alexandre B A Villares ]
Alexandre Villares
Please add to the wish list:
0 answers to this question
