Wall hatch for low wall shows in plan - how to change?
Modify your wall style so it does what you want.
Currently, your wall is inheriting that fill from somewhere.  You could post a file with the offending geometry and someone could tell you exactly how to fix it.  Without that there are at least 1/2 doze settings that could be causing your issue.
6 hours ago, Todd W said:
I have a low wall which shows the hatch in plan. I would like this hatch to not be shown as it is not in cut-section. Please see attached pics - any way to do this?Screenshot 2024-07-10 at 6.06.48 PM.pdfScreenshot 2024-07-10 at 6.07.11 PM.pdf
If you don't want to edit the Wall Style you could use a Data Visualisation to display that particular Wall with a solid white fill. Use 'Wall Overall Height' as the Display Criteria + select 'By Ranges', then you can override the fill for all Walls within a certain height range. Save the Data Vis in your user folder + you can access it from future files where the same thing occurs.
