mark4 Posted July 10, 2024 Share Posted July 10, 2024 I'm new to Spotlight, but I have created this stage with lighting and can only "turn on" and adjust 4 fixtures at a time. In the attachment, only the fixtures on the right truss are on. No other fixtures can be turned on, unless I first turn these off. Being that I copied and pasted the fixtures initially, is this due to them not having unique addresses or names? Secondarily, I can't seem to always adjust the colors correctly? Those 4 fixtures are set to be "white", not blue. But this may be the result of the above problem? Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted July 10, 2024 Vectorworks, Inc Employee Share Posted July 10, 2024 Hello @mark4 This may be the legacy 8 light limit for Shaded render mode, this can be turned off in the Document Preferences dialog. 1 Quote Link to comment
mark4 Posted July 10, 2024 Author Share Posted July 10, 2024 You are correct! I suppose that limit is selected just to conserve resources and processing time? Anyway, that did the trick, thank you so much! Can I also add another challenge? I'm trying to add the speaker arrays to this but the only thing that shows are the "bumpers", not the cabinets below. Attached is a screen shot of the array config. Any thoughts? Quote Link to comment
mark4 Posted July 10, 2024 Author Share Posted July 10, 2024 Nevermind, figured that out. Thanks again! Quote Link to comment
