vwx crashs after symbol out of object node from a wrapper?
Hi,
i made some kind of rastered dowels for my cabinets, because the cabinetcreator of IC does not allow applying dowels in backplates.
So i made this small marionette to have a red symbol which can be placed as a "box object" in the cabinets which is adoptable to the cabinet measures.
network run - works
wrapping - works
object node - works
symbol of "object node" - VWX CRASH
does someone knows, whats wrong with my network?
BR KC
Duebelmarionette als Boxobjekt forum.vwx
  • 2 months later...
Hello KingChaos,
unfortunately, it worked without any issues for me. Attached is the file with the marionette style (symbol). I think you are aware that an error is generated if the script is below a certain length, as the calculation doesn’t work out. However, this doesn’t cause a crash for me. The script just behaves oddly, but it continues to run.
Hope you find the error.
GL & HF
Duebelmarionette.vwx
