grant_PD Posted June 20, 2024 Share Posted June 20, 2024 Does anyone know of a specific software or plugin that does product assembly? It seems like a very straightforward thing that would have it's own software package. I have a potential project I'm looking at and don't want to reinvent the wheel.. 2 Quote Link to comment
Pat Stanford Posted June 20, 2024 Share Posted June 20, 2024 Can you expand on what you mean by "Product Assembly" I do mechanical systems with lots of pumps, valves, and instruments. and I am able to do these acceptably in VW, but I typically have a few hundred parts. If I was trying to build a car or an airplane it would probably not work. I am trying to build up my library files with symbols with attached records so I can reference those objects into a drawing and pull all the data I need. But it is a slow process. What functions are you looking for? VW does not offer anything like an exploded view which is one of the things I would like to have. 1 Quote Link to comment
Kevin Allen Posted June 20, 2024 Share Posted June 20, 2024 I've made exploded views with VWX but it is a bit of a PITA 1 Quote Link to comment
EAlexander Posted June 20, 2024 Share Posted June 20, 2024 (edited) I haven't looked at it in a while, but I think Fusion 360 has capabilites that might suit your needs? Edited June 20, 2024 by EAlexander Quote Link to comment
spettitt Posted June 22, 2024 Share Posted June 22, 2024 As a daily user of both Fusion (no 360 anymore) and Vectorworks, Fusion does indeed do lots of things that are geared towards the assembly of products rather than a more general CAD platform like Vectorworks. The biggest thing probably being the browser/tree - where you can visualise the component/assembly structure of your design - seeing the bodies, components and subassemblies within your assembly, which is something that VW just doesn't do. It's a typical feature of any of the design platforms from the 'Product Engineering' sector - Inventor, Solidworks, Fusion, Catia et al. It's just a different sector from more general design CAD like Vectorworks, AutoCAD etc. All it is is a UI element that would show a tree of your used Symbols, what Symbols they contain and what primitives are within then...you've given me an idea now 😉 The other thing is the historical modelling element. Vectorworks does kind of do historical modelling, but it's a baby version compared to Fusion, and you can't really 'see' the history like you can in Fusion. When you're developing a complex design with hundreds of components, you sometimes need the ability to say 'right, that's OK, but make the whole thing 10mm longer' and not have to go and move/edit lots of stuff - just change one parameter and everything recalculates/redraws. Also, quite a lot of assemblies use motion of joints and computing of contact. I'm not saying Fusion is 'better' than Vectorworks at all - they come from different sectors. I'm actually trying to move modelling tasks to Vectorworks unless they need to be in Fusion. Building a historical parametric assembly with animated joints in Fusion is quite complex - I often say that I get 'Fusion Fatigue' if I do a day in it. But I do think that some of the features from that sector of software platforms could really improve Vectorworks and maybe even draw some users from that market. I might put a few feature requests in. - Browser/Tree - Better display/insight of historical modelling - Joints with constraints and motion (Before any of that though, it just needs to walk before it can run and at least handle a STEP file properly, my request of which hasn't moved yet...) 4 Quote Link to comment
