Customise existing PIO Edit Dialogue
Hi,
I'm relatively new to VectorScript and wondering if it is within the realms of possibility to have a script/plugin that either overrides the existing Pop-up edit window when I double-click a Socket in connectcad, or comes up with a custom dialogue window.
I'd like to add a few fields to this popup to tie in with some of my custom records. Is this possible?
Thanks!
I don't think what you want is possible.  The edit window popup is deep within the object.
What is probably possible would be a menu command that would open a custom dialog box and then take the entered data and store it into the parameter record for the  object.
If you added the command to the Right Click menu of your workspace it would be reasonably accessible, but not a smooth as double click.
