Plant 'tik marks' are not following "Rotate Plan" screen rotation.
This happens now and then.
(Edit to say you have to draw them in a rotated plan to make it break... if drawn in 0deg then it works as expected.)
Here is a plant group with "Rotate Plan" at 0deg - tick marks are at the center of the plant object - as expected.
Here is the exact same plant group with "Rotate Plan" is at 90deg --- the tick marks are staying at 0deg:
Have to reset the tik marks manually when returning to 0deg by choosing "none" and then back to "cross", they don't reset by themselves.
The other Landmark tool that doesn't like "rotate Plan" is the "existing tree tool"
Edited by hollister design Studio
1 answer to this question
