ChollyO Posted June 18, 2024 Share Posted June 18, 2024 I'm trying to adjust the DMX footprint for a Chauvet Rogue R2X fixture as the size does not match the fixture mode we plan on using in our design. Why is it that the footprint is greyed out in the OIP and in the edit fixture window? It is locked into 56 channels and we're going to use them in 17 but I cannot adjust it. Anyone know how to change this value? Quote Link to comment
markdd Posted June 18, 2024 Share Posted June 18, 2024 Is it assigned to a Fixture Mode? You'll find this at the top of the Object Information Palette. If so, the footprint will be controlled by that. Either assign the correct mode or set it to None. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted June 18, 2024 Vectorworks, Inc Employee Share Posted June 18, 2024 The DMX footprint is set in order based on: 1. GDTF Mode 2. Fixture Mode 3. Symbol Information If a GDTF Mode or Fixture mode is set the DMX footprint will be disabled as the footprint is defined by the selected mode. Quote Link to comment
ChollyO Posted June 18, 2024 Author Share Posted June 18, 2024 @klinzey Got it. It was the GDTF Fixture Mode. Thanks for the tip. Quote Link to comment
