Change title block double click response
Hello friends,
Using VW 2022, I inadvertently set something that I can't figure out how to undo.  When I double clock on the title block to edit it, I used to get a dialog box with a list of things I wanted to edit: layout, data, etc.  Somehow I set to to always edit layout when I double click on the title block, which I don't want.  I can't figure out where to change this back so I get the dialog box.  Any help is appreciated.
Right click on the title block and choose Edit. You will get the Edit Title Block dialog box you are used to.
In the center of the dialog box is a pop-up that lets you pick what the double click behavior is.  Change that back to "Displays this Dialog" and you will have your old performance back.
