michaelk Posted June 17, 2024 Share Posted June 17, 2024 I'm seeing weird section behavior with lighting devices. When a lighting device is on the section line it shows in its default symbol orientation pointing straight down. When a lighting device is behind the section line it shows in its focused position. Is there a trick to get lighting devices that are on the section cut line to show in their focused orientation? Quote Link to comment
markdd Posted June 17, 2024 Share Posted June 17, 2024 I think you have discovered a bug. You certainly used to be able to section a lighting device without it losing its focus orientation. If you right click on the section viewport and select edit section in place, then you can select the lighting device and you’ll find a cut plane and display button in the Object Information Palette. Click on it and select the cut plane options to show it either uncut before or after the cut plane. 1 Quote Link to comment
michaelk Posted June 17, 2024 Author Share Posted June 17, 2024 Thanks @markdd! That works great. Quote Link to comment
