Tomas Lohin Posted June 14, 2024 Share Posted June 14, 2024 Hi. How do I distribute lighting devices on i.e. round truss, a non-linear pipe, 2D polygon or 3D object? In cases straight line of Align/Distribute tool is not the solution? Quote Link to comment
VIRTUALENVIRONS Posted June 14, 2024 Share Posted June 14, 2024 This may be a two step process for your problem. Duplicate Along a Path was designed for this, but you need to extract or create a path on the solid object. Post a file with a description of what you want to do? It will be easier to help. Quote Link to comment
JBenghiat Posted June 14, 2024 Share Posted June 14, 2024 There is not currently a tool for this. A number of solutions exist for creating/duplicating around an arc, but not for distributing existing objects. My solution has been to use the lighting pipe's tick marks. In the case of a truss, I insert a Lighting Pipe along a chord and turn off the "Draw pipe" option, which leaves only the tick marks. I have a script which distributes along an arc, but last I checked a bug in VW made it crash when picking the center point. 2 1 Quote Link to comment
Tomas Lohin Posted June 18, 2024 Author Share Posted June 18, 2024 On 6/14/2024 at 5:23 PM, JBenghiat said: There is not currently a tool for this. A number of solutions exist for creating/duplicating around an arc, but not for distributing existing objects. My solution has been to use the lighting pipe's tick marks. In the case of a truss, I insert a Lighting Pipe along a chord and turn off the "Draw pipe" option, which leaves only the tick marks. I have a script which distributes along an arc, but last I checked a bug in VW made it crash when picking the center point. It would be nice to have possibility to draw tickmarks directly on a truss object. Now I use your workaround, if you don't mind 🙂 Quote Link to comment
