ben@gibson.co.nz Posted June 14, 2024 Share Posted June 14, 2024 My active document suddenly stopped backing up. I have tried changing the name and saving it to a different folder, I can't seem to save it anywhere. Quote Link to comment
0 Pat Stanford Posted June 14, 2024 Share Posted June 14, 2024 Could you plug in a USB Drive and save it there? Quote Link to comment
0 Elite Exhibits Posted June 14, 2024 Share Posted June 14, 2024 @ben@gibson.co.nz we have found that VW / files behave like this if the original location is moved or renamed also disconnected / reconnected ... Peter Quote Link to comment
0 vassen Posted October 17, 2024 Share Posted October 17, 2024 (edited) On 6/14/2024 at 6:37 AM, Pat Stanford said: Could you plug in a USB Drive and save it there? Dear Prat, I am currently having the same issue with all my vectorworks files. Even a new file which contain only a square shape is having the same issue. I have 2.18 TB free space. Is there any solution for this issue? Even PDF i am unable to generate. Edited October 17, 2024 by vassen Quote Link to comment
0 Pat Stanford Posted October 17, 2024 Share Posted October 17, 2024 @vassen I have no idea. I assume you have restarted the computer? I have not heard of others having this problem. And in that case I normally recommend that you contact Tech Support directly as they have far more information than I do. Sorry. Quote Link to comment
0 vassen Posted October 17, 2024 Share Posted October 17, 2024 On 6/14/2024 at 6:37 AM, Pat Stanford said: Could you plug in a USB Drive and save it there? Dear Prat, I am currently having the same issue with all my vectorworks files. 2 hours ago, Pat Stanford said: @vassen I have no idea. I assume you have restarted the computer? I have not heard of others having this problem. And in that case I normally recommend that you contact Tech Support directly as they have far more information than I do. Sorry. I have not restarted the computer. My Vectorworks 2023 just got crash last night. when i reopen the software and my files and other files i keep on receiving the same dialogue each time. Quote Link to comment
0 Pat Stanford Posted October 17, 2024 Share Posted October 17, 2024 Try restarting the computer. If that does not solve the issue then I recommend you reach out to Tech Support. Quote Link to comment
0 vassen Posted October 17, 2024 Share Posted October 17, 2024 Thanks Pat. I have restarted the PC 5 times and still same issue on my side. Quote Link to comment
ben@gibson.co.nz
7 answers to this question
