koenr Posted June 11, 2024 Share Posted June 11, 2024 Hello, Is there a way to let vwx wait for a specific callback before moving on with the rest of the script? Simple example: def callback(pt): vs.Message(f"selected point is: {pt}") def main(): vs.Message("Start task...") vs.Wait(1) vs.GetPt(callback) vs.Wait(1) vs.Message("Task finished!") if __name__ == "__main__": main() In this example above you see the first message and only after the second message i can pick a point. When i searched for a solution they said i need to set my second message inside the callbackfunction wich would be fine in the simple example but in my real command i want to click on a button inside a custom dialog → close the dialog to select a point → re-open the dialog with some data that was selected. the problem is that i can only pick a point after the dialog is closed and vwx will crashe. ... def DialogHandler(item, data): if item == kSetupDialogC: _b = vs.SetLayoutDialogPosition(dialog, 200, 150) if item == kselect: def callback(pt): h = vs.PickObject(pt) vint1 = int(vs.GetDimText(h)) vs.SetEditInteger(dialog, kint1, vint1) vs.GetPt(callback) if item == kOK: _b, rundialog.maatlijn = vs.GetEditInteger(dialog, kint1) if item == kCancel: rundialog.cancel = True return item ... Can someone explain how this is done or if it isn't possible at all. Thanks a lot! Quote Link to comment
spettitt Posted June 11, 2024 Share Posted June 11, 2024 I am interested in this as well. I have taken to just putting everything within the scope of the callback but I agree it is limiting. Quote Link to comment
koenr Posted June 15, 2024 Author Share Posted June 15, 2024 @spettitt I think i found a solution.. At least for the simple example it works so I hope I can use this at larger scale as wel but the idea i had was to use 2 global toglles and run the main code 2 times. See code snippet below: toglle_1 = False toglle_2 = True def callback(pt): global toglle_1 global toglle_2 vs.Message(f"selected point is: {pt}") toglle_1 = True toglle_2 = False main() def main(): # Code before the callback: # callback will run def main() again. # inside the callback toggle_2 -> False / toglle_1 -> True if toglle_2: vs.AlertCritical("Start task...", "") vs.GetPt(callback) # First runtime toglle_1 == False so return gets called. # Second runtime toglle_1 == True so nothing happens in the if statement. Run continues... if not toglle_1: vs.Message("Callback wordt geactiveerd...") return # Only gets here in the second run off the script. vs.AlertCritical("Task finished!", "") if __name__ == "__main__": main() I hope you can use this as well but it would make much more sense if vwx would would run the callback before running the rest off the script.. Quote Link to comment
spettitt Posted June 15, 2024 Share Posted June 15, 2024 4 hours ago, koenr said: @spettitt I think i found a solution.. At least for the simple example it works so I hope I can use this at larger scale as wel but the idea i had was to use 2 global toglles and run the main code 2 times. See code snippet below: toglle_1 = False toglle_2 = True def callback(pt): global toglle_1 global toglle_2 vs.Message(f"selected point is: {pt}") toglle_1 = True toglle_2 = False main() def main(): # Code before the callback: # callback will run def main() again. # inside the callback toggle_2 -> False / toglle_1 -> True if toglle_2: vs.AlertCritical("Start task...", "") vs.GetPt(callback) # First runtime toglle_1 == False so return gets called. # Second runtime toglle_1 == True so nothing happens in the if statement. Run continues... if not toglle_1: vs.Message("Callback wordt geactiveerd...") return # Only gets here in the second run off the script. vs.AlertCritical("Task finished!", "") if __name__ == "__main__": main() I hope you can use this as well but it would make much more sense if vwx would would run the callback before running the rest off the script.. Thank you, I'll put this on the list to test this week, appreciate that. I may be wrong, but I think the issue with the script progressing is more to do with how Python execution works rather than anything in the VW interfacing. I'm sure I've seen this mentioned somewhere before but can't immediately locate it. Quote Link to comment
koenr Posted June 17, 2024 Author Share Posted June 17, 2024 On 6/15/2024 at 3:26 PM, spettitt said: Thank you, I'll put this on the list to test this week, appreciate that. I may be wrong, but I think the issue with the script progressing is more to do with how Python execution works rather than anything in the VW interfacing. I'm sure I've seen this mentioned somewhere before but can't immediately locate it. I may be wrong but i'm pretty sure python just excecutes everything one after another. If you want to do multiple things together you must use multiple threads or use async function. It may be that this is the case for the "vs.GetPt()" under the hood but i can't check that. If you run just a normal callback you can see that it will execute the way it should. def callback(): vs.AlertCritical("Callback is running...", "") def foo(func): vs.AlertCritical("Function running...", "") func() vs.AlertCritical("Function ending...", "") def main(): vs.AlertCritical("Starting...", "") foo(callback) vs.AlertCritical("Ending...", "") if __name__ == "__main__": main() I also tried to fix my bigger script but with no luck.. Since my solution ends the main function and needs to run it again i can't use it inside a for loop. I hope there will come a better way of doing this.. Quote Link to comment
