SacSurfin'
Multi-mapping same object
Some of the 3d design programs I have used include an ability to put different textures on same object. The ability to number faces individually and assign different textures to the individual faces would be great. Thanks.
3 answers to this question
YOu can do this with walls currently, but not other objects.
Was there a specific type of object you'd like this for?
An application which comes immediately to mind Katie would be the cut surfaces of sectioned objects. Note that; Re the recent discussion on another thread about "SketchUp", that App can apply different textures to at least the opposite sides of objects.
cheers,
N.
For instance to make say a refrigerator, You make a rectangle and assign different numbers to each side. You assign the refrig. front picture to the front number aloong with the refrig. shape Opacity Mask and put side pictures on the sides and rear picture on rear, then presto a 15 minute frig. This could work with alot of things and could cut down modeling time tremendously. Cutting down on the amount of time spent trying to offset and measure object to have material map right.
