maiz02 Posted May 29, 2024 Share Posted May 29, 2024 Hello,  Does anybody know how to build a squared spiral staircase in Vectorworks 2024? I've only been able to build a round one with the 3D stairs tool...  Thanks in advance 🙂 Quote Link to comment
rDesign Posted May 29, 2024 Share Posted May 29, 2024 I think you’ll have to build it using direct 3D modeling - meaning that the built in stair tools will not be able to do what you want, but you can use the Stair tool spiral stair as a guide.  You could use the Stair tool to make a round spiral stair which has an oversized diameter so that it hits the outside points of the square. Then you can convert the Stair object to a Group and trim the treads to fit inside your square footprint. You’ll have to manually create the stringers, etc. 2 Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted May 29, 2024 Vectorworks, Inc Employee Share Posted May 29, 2024 This Is the closest I could get using the old Custom Stair, from here you can ungroup and finish modeling it. HTH squared spiral staircase.vwx 3 Quote Link to comment
maiz02 Posted May 29, 2024 Author Share Posted May 29, 2024 2 hours ago, JuanCarlos said: This Is the closest I could get using the old Custom Stair, from here you can ungroup and finish modeling it. HTH squared spiral staircase.vwx 2.65 MB · 2 downloads Thank you so much!! It seems like I can't edit the stairs with a double click and ungrouping makes it disappear straight away... Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted May 29, 2024 Vectorworks, Inc Employee Share Posted May 29, 2024 With the Custom Stair selected in a 3D view <Control U> (PC) <Command U> (Mac) > OK converts to 3d objects Extrudes and 3D Polygons, this allows to edit the individual pieces. HTH Quote Link to comment
shorter Posted May 30, 2024 Share Posted May 30, 2024 Just model it, and enjoy the moment! Quote Link to comment
