AEC Pillar (& other) rendering issues
Posted (edited)
VW24 added some new rendering controls to the AEC objects. I'm frustrated with the behavior—so for only w/ the Pillar and Structural Member objects—at two levels:
1).    Both objects—at least in our set up—default to a texture override of, I think, 'no texture'. If I select 'Reset to Default Mapping', the Class texture is applied and the object renders as expected.
2).    To pile one oddity on another, if any change is made to the object (adjust the length, adjust the underlying 2D geometry) the Object promptly resorts to the 'no texture' override which requires taking the extra several steps above.
Is anyone else seeing this behavior?
Is there a way to set/reset the underlying object default so it behaves as expected?
Oddity #1:
image.png.769edfd28bd12e9ba6ffe06381a48e75.png    image.png.213ae3ae0523c324afaad7ecc1d9ff3f.png
Edited by Travis
