InchSw3 Posted May 27, 2024 Share Posted May 27, 2024 (edited) Hello. How can I mitre the edges of the attached cornice moulding to join at the corner? Many thanks Edited May 27, 2024 by InchSw3 Quote Link to comment
VIRTUALENVIRONS Posted May 27, 2024 Share Posted May 27, 2024 Can you use the original 2D section and sweep it 90 degrees. Then put it in place. Quote Link to comment
InchSw3 Posted May 27, 2024 Author Share Posted May 27, 2024 This doesn't seem to achieve the required effect. Below is an image of essentially how this should be achieved. I thought maybe subtracting solids but this doesn't seem to work either Quote Link to comment
Kevin K Posted May 27, 2024 Share Posted May 27, 2024 I can’t quite tell from the image exactly what is happening there…can you post what you have so myself or someone else can resolve your issue? There are probably a few techniques to facilitate this. Quote Link to comment
bcd Posted May 27, 2024 Share Posted May 27, 2024 (edited) Several ways The easiest now is to extend both extrusions past the corner and in Top/Plan view use the Split(L) tool 2nd mode & throw the cutoffs in the recycle bin. Another way is to Select each cornice and in the 3d Modelling tool set Taper Face the end of it 22.5º - that's a more fun way. Finally A simpler way altogether is to draw the a polygon in Top/Plan for the full run of the cornice. Select this and the profile Model>Extrude Along path. Chances are - you will now need to Edit 2d of the EAP and move the profile to position. Take a look @ Chain Extrude to create the dental molding and mitres all in one go. Edited May 27, 2024 by bcd 4 Quote Link to comment
Kevin K Posted May 27, 2024 Share Posted May 27, 2024 1 hour ago, bcd said: Finally A simpler way altogether is to draw the a polygon in Top/Plan for the full run of the cornice. Select this and the profile Model>Extrude Along path. Chances are - you will now need to Edit 2d of the EAP and move the profile to position. bcd's suggestions are spot on, and actually, if you place the profile object right where it should go in 3d space in relation to the path object, no need to edit the profile...which by the way doesn't have to be a 2d object. The screenshot below is in wireframe so you can clearly see the profile and path objects. Note the profile for the crown moulding is hooked directly on to the path object in the correct orientation.... ...and looking up from below you get this after selecting 'extrude along path'......crown moulding created in one move, mitered corners and all 🙂 Quote Link to comment
VIRTUALENVIRONS Posted May 27, 2024 Share Posted May 27, 2024 This fellow has a slightly different problem. Granted a mitred joint can be done in many different ways, but this exterior moulding has those little pockets, which will affect how the actual joint looks. Both sides of the mitre have to look alike. It would be so nice if @InchSw3 would post the file, or just the moulding. Quote Link to comment
Kevin K Posted May 27, 2024 Share Posted May 27, 2024 Paul Yes, a file would speak volumes. I was merely pointing out some basics regarding constructing an etude along path. 1 Quote Link to comment
VIRTUALENVIRONS Posted May 27, 2024 Share Posted May 27, 2024 7 minutes ago, Kevin K said: I was merely pointing out some basics regarding constructing an etude along path. As usual, they were spot on. You seem to be burning the midnight oil. Paul Quote Link to comment
VIRTUALENVIRONS Posted May 27, 2024 Share Posted May 27, 2024 Raining heavy here and I am bored, so I made a short tutorial on how I would create this type of cornice. It may be of interest to anyone. I did not do any editing to fine tune things, just the basics. To be honest, it appears I am not the only one who is bored. The usual suspects seem to be jumping all over any real 3D questions and appear to get really excited if it involves NURBS. 1 Quote Link to comment
mjm Posted May 27, 2024 Share Posted May 27, 2024 1 hour ago, Kevin K said: …constructing an etude along path. Love this 1 Quote Link to comment
Kevin K Posted May 27, 2024 Share Posted May 27, 2024 yeah, especially how I spelled 'etude along path'!! friggin auto spell is the bane of my existence !! 🙂 1 Quote Link to comment
