node for making pulldown out of a preselection
i would like to have an oip port in my existing marionette, which has a pulldown out of this selection.
so i need a pulldownnode which
SelectObj(INSYMBOL & INVIEWPORT & ((T=POLY) & (N='*Poly*')));
and outputs the name of the selested polyline as a string.
someone has a clue, how to combine the filterselection with nodes?
BR KC
i manipulated the code of the node (after i consulted ChatGPT) to get an input port and i tried to output the n-th element of the list i inputted.
This works so far, except the selection is not "changing its selection choicenames" i think it has somethin to do with behaviour and run node complications.
2. if i wrap it, the named node is in the oip palette as a parameter.
the outputstring has to be cleaned so the 2 ' has to be removed.
Maybe someone has a clue, why the hack this is not reacting like i think it "shoud".
Edited by KingChaos
  • Marionette Maven
It's currently not possible to dynamically change the elements in the OIP popups within Marionette through the script.
I investigated a different solution a while back that involved using OIP Buttons and popup dialogs, I'll try to remember to look around for it in my free time.
