AI Visualizer Wishlist -An image History button and ability to "generate similar" to history images
This could be better in the wishlist forum, but AI Visualizer seems a bit separate from everything else right now so I've put it here.
I've used the visualizer a couple of times to 'de-computerize' some early concept sketches.
It does seem that you have to hit "generate" and "create bitmap image" quite a bit in order to find a visualization that meets your esthetic needs...
It would be nice if there was a history button so we could go through multiple visualizations and then look through to pick out the best.
I've also found that I look back at my saved images and think - wow, image number 3 was actually pretty good, I wish I could use that to 'generate similar' with different views of the project.
Maybe I'm miss-understanding what "Generate Similar" is, but if there was a 'history', it would be very nice to be able to use a past successful visualization to focus the new visualizations of all the views I want to render.
