kalollcell Posted May 23, 2024 Share Posted May 23, 2024 Hello I am new to vectorworks, look thru lots of tutorial and my brain is burning. I need help to construct a simple curve with arch line (see attached) what do should I use? thank you for your help. Kalo Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted May 23, 2024 Vectorworks, Inc Employee Share Posted May 23, 2024 Your image looks like a curved arc. Would you please post a copy of the file and a simple pencil sketch of what you're trying to create? Quote Link to comment
kalollcell Posted May 23, 2024 Author Share Posted May 23, 2024 Hello Scott, you are right, it is a curve. I am including the VW file drawn by someone else. I needed to modify the design, such as to change the height and the bottom wavey part but I couldn't quite figure out how it was done. Hope this makes sense. thank you. Curve fabric.vwx Quote Link to comment
VIRTUALENVIRONS Posted May 23, 2024 Share Posted May 23, 2024 Still a little unclear on what you want to do. You can use "extract" in the 3D tool palette to extract the curves. What is your objective after that? Paul Quote Link to comment
VIRTUALENVIRONS Posted May 23, 2024 Share Posted May 23, 2024 17 hours ago, kalollcell said: need help to construct a simple curve with arch line Here are the curves as you had them if this is what you need. Curves.vwxCurves.vwx Quote Link to comment
kalollcell Posted May 24, 2024 Author Share Posted May 24, 2024 Thank you! I think that is very helpful. Is that using loft function? Quote Link to comment
VIRTUALENVIRONS Posted May 24, 2024 Share Posted May 24, 2024 8 hours ago, kalollcell said: s that using loft function? All I did was just extract the curves. Still not sure what you are trying to do. Can you explain a little further. Do you want to apply a thickness or change the curve, etc. Quote Link to comment
