Editing text over distributor objects
I have a handful of distributor objects for data nodes (switches, gateways, etc) that were edited from the default "distro RJ45 splitter 8 way" object.  I'm using the ID field to record the nodes' IP address.   When there is content entered in that ID field, it automatically appears as text over the symbol.  I can not understand where or how to edit this characteristic in the editor.  Can anyone point me in the right direction?  I'd prefer to not have it display AT ALL, and I will add a label as I see fit on my own (which I can then hide without hiding the node itself).  Thanks.
Label is controlled from the object properties, using a combination of the text style dropdown and the classes button, these are found in the shape pane of the OIP.
