Benson Shaw Posted May 17, 2024 Share Posted May 17, 2024 Draw a layer plane rectangle. Objects from Shapes. Creates 4 walls, but one corner is not joined. Work around is to start with or convert to a polygon, but why doesn't the rectangle just make the join at all corners? -B 1 Quote Link to comment
0 Tom W. Posted May 17, 2024 Share Posted May 17, 2024 I never create Walls this way but have tried just now + it is working fine: all corners joined when source shape is a Rectangle. I tried different Walls + different offsets + was the same each time. Not sure why it's different for you...! Quote Link to comment
0 Kevin McAllister Posted May 17, 2024 Share Posted May 17, 2024 (edited) 8 hours ago, Benson Shaw said: Draw a layer plane rectangle. Objects from Shapes. Creates 4 walls, but one corner is not joined. I get the same result here - an unjoined corner. It's the same corner that would be open if you converted the rectangle to a NURBS curve. Noting that Benson's signature says Update 4 and Tom's says Update 5. I'm using Update 4.1. Kevin Edit> I updated to Update 5 to test this and now none of my tools work, sigh 😔 Edited May 17, 2024 by Kevin McAllister 2 Quote Link to comment
0 zoomer Posted May 17, 2024 Share Posted May 17, 2024 9 hours ago, Benson Shaw said: Draw a layer plane rectangle. Objects from Shapes. Creates 4 walls, but one corner is not joined. I always thought that way would be a VW standard. 1 Quote Link to comment
0 Benson Shaw Posted May 17, 2024 Author Share Posted May 17, 2024 Solved. Update to 2024-5 and updated forum signature. The rectangle>Obj from Shapes>Walls creates 4 joined walls as expected. Thanks @Kevin McAllister for kick in pants to update. Except your edited comment regarding other tools. Need to test more tools and commands. Will report of anything found. -B Quote Link to comment
0 Kevin McAllister Posted May 18, 2024 Share Posted May 18, 2024 Solved here too. The tool problem and the wall problem. Updating my Mac to 14.5 solved my tool problem. Update 5 seems to solve the wall issue. Kevin 2 Quote Link to comment
Benson Shaw
-B
5 answers to this question
