oswaldoRN. Posted May 16, 2024 Share Posted May 16, 2024 hola estoy teniendo problemas con la conectividad entre vision y ma2 onpc. al momento de dar dmx provider indica un error de (C:/Program Files/Vision 2024/DmxProviders/grandMA.dll Cannot load library C:\Program Files\Vision 2024\DmxProviders\grandMA.dll: Unknown error 0x000000c1. el momento de seguir con los pasos elemina del menu el manet2. Quote Link to comment
Pat Stanford Posted May 16, 2024 Share Posted May 16, 2024 Translation via Google Translate: Quote Hello, I am having problems with the connectivity between vision and ma2 onpc. When giving dmx provider it indicates an error (C:/Program Files/Vision 2024/DmxProviders/grandMA.dll Cannot load library C:\Program Files\Vision 2024\DmxProviders\grandMA.dll: Unknown error 0x000000c1. The moment you continue with the steps removes the manet2 from the menu. 1 Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted May 17, 2024 Vectorworks, Inc Employee Share Posted May 17, 2024 I'm not sure if these would be helpful or not: University Article: https://university.vectorworks.net/course/info.php?id=578 DMX Connectivity Articles: Even though some of that information is for older versions of Vision, the concepts should be more or less the same. You can also call into Tech Support. They can try to get you up and running! 1 Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 17, 2024 Vectorworks, Inc Employee Share Posted May 17, 2024 You may need to repair or re-install Vision. If you run the install the MA2 driver from MA after you install Vision it will install the driver in the wrong location and overwrite the driver installed by Vision. 2 Quote Link to comment
