AlanW Posted May 14, 2024 Share Posted May 14, 2024 Hi, Thought i should try Datasmith again. All good until i go to plan view in Vectorworks, the Twin Motion says VW has stopped exporting a 3d and you lose half of the model in TM. When you re sinc the file via the datamith Direct link auto sync you get a model without all the textures you placed on in TM. Is anyone else experiencing this? Will have to go back to Exporting in CD4 format. Thanks in advance. 1 1 1 Quote Link to comment
0 Grethe Connerth Posted August 31, 2024 Share Posted August 31, 2024 Hi, I find this one of the most frustrating things using Datasmith. I use a work-around, which unfortunately is rather time consuming. I export VW Design Layers individually. So that the changes in textures are limited to only the Design Layers I make changes to. Not great but it helps a bit. When exporting via CD4 all files have to be turned by -90 degree … Quote Link to comment
AlanW
Hi,
Thanks in advance.
1 answer to this question
