Letti R Posted May 13, 2024 Share Posted May 13, 2024 Hello, I found this "weird" behaviour of the "Objs by Crit" node: If i create the criteria via the "Objs by Crit" node to search for all objects where the name is equal to an empty string, i get the hint in the criteria configuration menu, that no such objects were found (as expected). However if i run the node i get all objects that do not have names. By the way, the "Name" node does not return any obejcts when given an empty string. Regards, Letti Quote Link to comment
Silvano Mainardes Posted May 13, 2024 Share Posted May 13, 2024 the same thing happens here. Quote Link to comment
Marionette Maven Marissa Farrell Posted June 5, 2024 Marionette Maven Share Posted June 5, 2024 I submitted a bug for this issue, thanks! Quote Link to comment
