FBernardo Posted May 10, 2024 Share Posted May 10, 2024 Hi all, I'm finding it hard to shrink the options on the similar tool to just select the data tags I want for example windows data tag instead of all data tags. If I use the OBJECT TYPE and CLASS only for example when I click on top of the data tag it won't select anything, and the options I have on the tool palette are Select Any Object Mode, and I've tried with both Modes. Any suggestions??? what would be the best options here: (image as example) If I select the SYMBOL option (which DATA TAGs are not) it always shows this image: Quote Link to comment
MarcelP102 Posted May 10, 2024 Share Posted May 10, 2024 You can try out my plugin: https://marcelplomp.gumroad.com/l/fqmyr?_gl=1*bbyizh*_ga*MTc4MTc0MTU0MC4xNzE1MzQyODQy*_ga_6LJN6D94N6*MTcxNTM0Mjg0MS4xLjEuMTcxNTM0Mjg4MC4wLjAuMA.. 1 Quote Link to comment
FBernardo Posted May 13, 2024 Author Share Posted May 13, 2024 On 5/10/2024 at 1:08 PM, MarcelP102 said: You can try out my plugin: https://marcelplomp.gumroad.com/l/fqmyr?_gl=1*bbyizh*_ga*MTc4MTc0MTU0MC4xNzE1MzQyODQy*_ga_6LJN6D94N6*MTcxNTM0Mjg0MS4xLjEuMTcxNTM0Mjg4MC4wLjAuMA.. While I appreciate the adding new tool, I know that there is a way to select the tags easily with the magic wand, I need to enter on a test mode to find it out and then save it as settings. I was also trying to see if anyone was having the same issues and if so, I would create a VE for the tool, if this makes sense? Quote Link to comment
