  • 1
Who would like to be able to access titlesheet parameters via the OIP?
shorter
We can access and hide parameters for other objects but not the titlesheet, so if we set up the ttlesheet to generate an ISO19650 compliant document reference, we have to edit the titlesheet by double-clicking, entering the titlesheet dialog, entering the value, e.g. Spatial Breakdown = 100L, and exit the sheet, wasting 10-15 seconds of one's life.
Whereas...
OIP Parameter...
Click on sheet, enter parameter, hit return.
6 answers to this question
Whereas...
OIP Parameter...
Are you referencing Title Block Borders with "titlesheet"? If so, you should check out VW 2024 where it is already possible to display all TBB data in the OIP.
5 hours ago, dvdvarch said:
Hi, I have missed this option how is it possible to show title blocks data in OIP in VW2024? Thank you,
On the OIP "Data Display Settings..." fourth button down in standard OIP.
Good addition. Could we maybe get an option for all non-style parameters to be displayed?
Please add a VE about this and it will be considered.
