t-bud Posted May 2, 2024 Share Posted May 2, 2024 Is there a way to have a user field default to be displayed when creating an Equipment Item from a device? For instance, I am using User1 for IP Addresses on both the Device and the Equipment Item. I would like to have that address shown on the face of the equipment in the rack. I can go into the Equipment Item, and make the text pull the data from the user field, but I have to do it for every piece of equipment. and that is really tedious, especially now that it is all done in 3D. It would be nice to be able to map that to a location, like the Name, Make and Model already are. It would be REALLY nice, if it was able to be linked to the device information. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted May 7, 2024 Vectorworks, Inc Employee Share Posted May 7, 2024 Hello @t-bud, You can set up an equip item symbol with the linked texts set up as you wish. Then you can use this symbol to create new equipment items either by drag&drop from the resource manager or by double clicking on the symbol and placing it with the equipment item tool. That way you will have your linked texts set up only once fro this symbol. Let me know if this helps. Best Regards, Nikolay Zhelyazkov Quote Link to comment
t-bud Posted May 15, 2024 Author Share Posted May 15, 2024 Is there a way to make this work when creating Equipment from a schematic Device? Or do I have to drop them separately, and match the name to the Device? Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted May 16, 2024 Vectorworks, Inc Employee Share Posted May 16, 2024 18 hours ago, t-bud said: Is there a way to make this work when creating Equipment from a schematic Device? Or do I have to drop them separately, and match the name to the Device? After you double click in the symbol in the resource manager it will be used by the equipment item tool and the Create Equipment menu command. Quote Link to comment
