filip Posted April 26, 2024 Share Posted April 26, 2024 dear users, does anyone know how to change the grafics of a nurbscurve? Filip Bosscher Quote Link to comment
VIRTUALENVIRONS Posted April 26, 2024 Share Posted April 26, 2024 Need a little more info on your question. Is this what you are trying to do? See below. Quote Link to comment
filip Posted April 30, 2024 Author Share Posted April 30, 2024 Yes this is exactly what I like to do; sometimes I want so show a solid nurbscurve in a dashed line. (some of the nurbscurvelines need to be dashed, then the drawing communicates much better) regards Filip Bosscher Grote liggende kraag.pdf Quote Link to comment
VIRTUALENVIRONS Posted April 30, 2024 Share Posted April 30, 2024 if your NURBS curves are in the same plane (2D) you can use the "Convert to Polygons" under the Modify menu. Then apply a line type. But, if your NURBS cures are 3 dimensional like the curve I have shown, this will not work. I have used a "workaround" for that curve. It appears your requirement is 2D. See if Convert to Polygons works for you. Quote Link to comment
filip Posted May 22, 2024 Author Share Posted May 22, 2024 thanks for your advies, it works Quote Link to comment
