Underwater Scenes
During the testing of this AI, I found that underwater images are not an easy task. The prompt is fighting me a bit even though I described every piece I can think of. Because of the randomness, I got the tanks in different places, fish are easy, caustics are hard. I also found that creativity plays a big roll, the higher the better quality but deviates from the source image. After about 30 something attempts, I think I got a decent concept. Now is your turn.
HI Luis,
First of all, let me say that I think these images are fantastic, especially the last one.  You have skill.
But, it wasn't what I was referring to.  I was referring to Ocean water above and below.  I don't know if this would be easy or a challenge for the Visualizer.
It is the below water I am most interested in.
There are two images and a short video enclosed.  For reference, everything was modelled in Vectorworks and rendered in CINEMA 4D.
Ocean View above water (two images)
Submarine view below water.  Normally I would enclose a link, but Youtube really pixelates under water scenes, so I uploaded a short movie.
You may not have tried this yet, so many areas for you to cover.  If you do go at this, I would love to see the end results.
TYHOONSURFACE_2_0659.thumb.jpg.f2575ebb15ad283530fffd287a064bbf.jpgTYHOONSURFACE_3_0659.thumb.jpg.b32ee4a2e870c5c073bd1479e2f240de.jpg
@VIRTUALENVIRONS
That was certainly a challenge. Getting a decent prompt took some time. I had to get help from ChatGPT to learn about some of the key words that would help trigger the deep sea scene.  Certainly the creativity level needed to be high because I only had two elements in my file, a crude submarine and a subdivision floor with lots of bumps.
  • 1 month later...
This is so cool.  I asked you once if you could animate and said "nope".   What changed?
Both animation are impressive, but the top one more so, although the deviant fish is a surprise.    The Frame rate appears higher.  Can you choose the frame rate or prompt the frame rate?
Also, how did it choose the couple's looks, etc.?
Paul,
The software used for animation is similar to what is provided in Vectorworks.  Both use a prompt as a starting point.  The video AI is just using the initial 2D image as context  to predict what might create a convincing movie based on the prompt.  The richness of the context seems to influence how far it can take the video currently.  You should try it out yourself, it's not like it's hard to do.  Go to https://lumalabs.ai/dream-machine
Here are some popular memes turned into AI video
https://nitter.poast.org/hey_madni/status/1801900554488291414#m
You might recognize this...
Hi Jeff,
Yes, I do recognize this.  It is very close to the actual jet.  Even 3D models have many inaccuracies as the jet has not been seen for sixty five years.
Is this your work?
I may try the software if it works on a Mac.
As I pull most of my images from my movies, the images are rendered at an intermediate level to get frames rendered at under 90 seconds per frame.   This still took much longer, but is close to the actual jet and also more photorealistic.   You can see the notched wing and an indent in the fuselage.
3 hours ago, VIRTUALENVIRONS said:
Is this your work?
It’s not my “work”.
It’s a random image found with google + a prompt typed into the aforementioned website.  That’s basically how all this AI content is being generated, online… not software that runs on your local computer.
