Drone survey: import your pointcloud with correct georeference
When you import a point cloud as is - without centering it on the internal origin as to keep it in its geolocation, you will get a point cloud that is visually corrupted, as in, it will have ugly lines... and the x,y coordinates say 0 while you can see in the rulers that is not the case...
Some time ago I reported this as a bug. I think it still is, as this should work properly so not to loose the correct georeferencing and have a nice workable point cloud.
pointcloudcorruptScreenshot2024-04-17at15_40_55.png.06da95f85886a348c56126ef3d8cc5b2.png
The solution I found for this now is
1. import the geotiff generated by the drone (using the settings of the geotiff - units and EPSG)
then
2. adjust the internal and user origin so they coincide with the midpoint of the geotiff
and finally
3. import the point cloud ticking the box 'Center Import on Internal Origin'
So - you need to export a geotiff and a point cloud from your drone to be able to use the pointcloud in GIS
RESULT of 1-2-3
Edited by Carol Reznor
  • Like 3
This is a massive pain. I submitted a bug about it as well. VB-202892. It's crazy that you have to jump through these kinds of hoops in order to import a point cloud into a georeferenced file.
then
and finally
Is Step 4 to Set User Origin to match the Georeferencing coordinate system?
@Tom W.
That is a good practice I find and my personal preference to indeed set it (the user origin) back to match the CRS - especially if you export to DWG because otherwise the DWG will read what the rulers say and import incorrectly ( check the box export dwg with georeferencing puts a Geographic marker in the file in autocad) ... BUT for architects... if you want to export to IFC you shouldn't as IFC only works with 1 origin, so in that case they (internal and user origin) should stay in one place.
hoop hoop hoop 🙂
  • Like 3
  • 1 month later...
  • 7 months later...
On 5/22/2024 at 8:57 AM, Carol Reznor said:
So... in a following project... this seems to not work as the orthophoto and the pointcloud are NOT exactly the same. They cover a different area so the midpoint of both objects is not the same...
Back to square one... no good way to georeference a pointcloud.
Hello
there is some update on this direction?
Thanks
  • 1 year later...
@Christiaan, Yes, the point cloud georeferencing is actively being implemented, right now. We're doing a lot of work on georeferencing as a whole, and the point cloud import is one of the parts. This will resolve the issue with the import location.
This also ties into the other discussion about working in plan rotation or georeferencing the file. Georeferencing is a unifying 'translator' for collaboration - if you have your file georeferenced, you can work together with many other file formats, and the files just 'fit together.' It's not so much about the internal Vectorworks workflows,  but more about how you share your work with other parties.
  • Like 3
  • Love 1
That's great, thanks Katarina.
And you don't think that working in a rotated view, or having one file with the site model set to north up the page + building model files referenced into that achieves this?
