I would like to see a coulple of improvements to the Save Sheet/Edit Sheet dialog:
1. The scrolling list of sheet names to select should be available from within the saved sheet dialog, so if you want to edit more than one sheet, you would not have to keep exiting the dialog completely, then going through a two step process to get back in the dialog to edit another sheet. It would be nice to be able to switch between any of your sheets to edit them before clicking "O.K." and exiting the dialog.
2. It would be nice to have a "Fit to Window" checkbox option in the Save Sheet dialog. In our office we have 17" & 19" displays, and both Flat panel and CRT's all running at different resolutions. When you save a sheet to " Restore View", which display do you set it up for? The same "view" loooks quite different at different resolutions. A "Fit to Window" option would always fill the window on any display when a sheet is chosen. This way, a sheet saved on a larger display would not have the window cropped off when the same sheet is chosen on a smaller display.
PeterT
3 answers to this question
