Points on intersection points on poly
les
Hello Sebatain,
The node "Infinite Intersect" is originally designed only to determine the intersections of two lines, or between multiple lines in one input and one line in the other input. It thus requires an iteration to allow this over multiple lines. In the attached document, I have modified the "Infinite Intersect" node and added two nodes from DomC, "Items to List". Now the script works as desired:
Points on Poly 240409.vwx
Best regards, KroVex
