Is there a way to get viewports to wireframe render?
I'm trying to model an existing structure. I've got dxf wire models representing scans from my Disto s910. I wish to measure and manipulate bim geometry in reference to those scans.
Elevation Level Benchmarks attached to story levels seem to only appear in viewports.
So how do I get my viewport to render wirefrane so I can dimension, view, and manipulate everything?
Thanks,
Rudy Beuc
Section Viewports cannot be set to Wireframe, only regular viewports can. Could you make a regular viewport of your model just looking from the appropriate side (Front, Left, etc)? Then you could set it to wireframe.
Or, if you need it to be a Section Viewport, you could try setting the Background Render to Dashed Hidden Line, then under Background Render Settings you could set the dash style to be Continuous and black. I think the result would essentially look like wireframe.
Edited by Andy Broomell
