lalcaraz Posted January 30, 2002 Share Posted January 30, 2002 When sorting by Channel, the numbers would appear as follows:110111213141516171819220etc. This is a seeting in Excel and LW deals with this problem -- is there a way to fix this? Thanks Lonnie Quote Link to comment
kmoore1 Posted January 30, 2002 Share Posted January 30, 2002 quote: Originally posted by lalcaraz: When sorting by Channel, the numbers would appear as follows:110This is a seeting in Excel and LW deals with this problem -- is there a way to fix this? Thanks Lonnie At the very bottom of the list are the fields Alt-Chan, Alt- Dim, Alt-Circ. IF you add this as a worksheet column and sort by these fields it will sort correctly in the worksheet. These fields aren't editable as the instrument only pushes data into the field, it never reads from the field. Because of this you'll also want to add the corresponding regular field to the worksheet. Quote Link to comment
