Iainy1961 Posted April 1, 2024 Share Posted April 1, 2024 Would anyone have some advice on how to make the hidden line drawing look like something please? I would like the rear backdrop to have some definition and I can;t seem to get a hatch fill into the floor. Thanks, Iain Quote Link to comment
Kevin Allen Posted April 1, 2024 Share Posted April 1, 2024 Is that a curtain/softgoods object? Increase the visual fullness. Quote Link to comment
EAlexander Posted April 1, 2024 Share Posted April 1, 2024 You wont be able to get shading out of Hidden line - it is just....lines. If you look at the Object info pallet for your Viewport - there is background render and foreground render - so essentially, you can stack rendering styles in one viewport. So you could try shaded (without show edges) for the background and hidden line for the Foreground render. Of some other combination - just keep in mind that render styles happen to the whole scene, so you wouldn't be able to isolate just the floor and drape with a style. Alternatively, you could add a hatch or pattern to select areas by drawing polygons/polylines in the ANNOTATIONS of the viewport and moving them to the back. e. 1 Quote Link to comment
BartH Posted April 2, 2024 Share Posted April 2, 2024 You could try an "Artistic-Lines and Shadows" style to get the curtains: The floor will still be a trick, but two stacked viewports might get you there. Quote Link to comment
