Astera Titan Tube
Iainy1
Hi there, is it possible to make the 2D representation of the Titan tube to be 1m long instead of just a circle? At the moment I have drawn in dummy tubes, then switched to a front or top view and manipulate the tube positions from there. It is very time consuming. I have read up on symbol editing but I am afraid it is beyond my capabilities at this stage in my Vectorworks learning curve. Thank you, Iain
1 answer to this question
All you have to do is go into the 2D Component of the symbol and remove the circle and add the rectangle that you wish. You can class the rectangle as you desire and set your line weights. Doing so will not cause any issues with the functionality of the symbol. Vectorworks is not going to ship a changed version of the 2D geometry so this change will have to be made by the user if desired.
