Curved Grades to Modify Site Model?
Hi All,
I have recently switched from using aligned hardscapes to draped hardscapes with a site model modified by using grades.
Generally it works great!
Issue with curved pathways: Is the simplest way to create a curved fall in the site model via nurbs curves set to the DTM class? I saw on one thread where that was suggested.
It is ok just a pain when you are modelling top and bottom of kerbs along a falling curve. Also a pain on designs with lots of curves.
Maybe a way to create curved grades??
Regards,
Jack
Try the Site Modifier in Pathway mode. Here you can create any shape you like, with curves. The pathway has a longitudinal profile that can be modified to set precise elevations, You can also create as many transverse profiles as you like. The pathway starts out with a fixed width, but you can reshape as required,
Once you’ve created your path modifier, add the hardscape and tell it to drape.
Hope that helps.
