Editing Symbols in Vectorscript
I want to do something that I thought was rather simple but I can't get it to work.
I have a symbol called SYMBOLSC which I obtain the handle of:
   SymbolHandle := GetObject('SYMBOLSC');#
Then I place it.
   Symbol('SYMBOLSC', 0, 0, 0);
Now I want to edit its properties.
   SetAngle(SymbolHandle, angle);
I am not quite sure what the SymbolHandle refers to, the last inserted instance of the Symbol or all instances of the Symbols?
At any rate I can place the symbol but I am not able to get the SetAngle() part of the code to work, same is true for SetWidth() etc.
DelObject(SymbolHandle); is working though which makes me think that there is a problem with editing symbols in general.
Would anyone be able to help me with that?
Thank you for your reply! What I exactly do to the symbol doesn't really matter yet since I am still trying to figure out how to edit it at all.
I've tried now:
PROCEDURE SYMBOLROTATE;
VAR
    SymbolHandle: HANDLE;
    xLoc, yLoc: REAL;
BEGIN
GetSymLoc(SymbolHandle, xLoc, yLoc);
HRotate(SymbolHandle, xLoc, yLoc, 100 );
Message(SymbolHandle, 'coord: ',xLoc, yLoc); {just to test it}
ReDrawAll;
END;
RUN(SYMBOLROTATE);
This doesn't do anything except inserting the symbol. I am not sure what the handle exactly refers to and how to edit the symbol once I inserted it. (I know I can rotate the symbol when I insert it, but I would like to know how to edit symbols in vectorscript in general.)
I'm not the most qualified on this forum to answer VS questions - but…
I usually use something like
SymbolHandle := LNewObj;
LNewObj returns a handle for the last object created by the currently executing script.  That way there's no confusion if you have a handle to a symbol instance or a symbol definition.
Is going to get you a handle to the symbol definition, not the symbol instance places in the drawing.
Use Michael's suggestion of
LNewObj works as a handle, Thank You!
I would like to scale the inserted symbol by a certain factor now.
None of the commands I tried like HScale2D or SetWidth appear to work. Is the a set of property changing commands that work on symbols?
Then I must be making a mistake.
PROCEDURE SYMBOLSCALE;
VAR
    xLoc, yLoc: REAL;
    scaleX, scaleY: REAL;
BEGIN
Symbol('SYMBOLSC', 0, 10, 0);
scaleX:= 1.5;
scaleY:= 3;
HScale2D(SymbolHandle, xLoc, yLoc, scaleX, scaleY, TRUE);
ReDrawAll;
END;
RUN(SYMBOLSCALE);
It pasts the object but doesn't scale it.
@FMA  You didn't get it wrong.  I did.  I use the following to scale a symbol instance
ObjArray
Symbol(SymHdl, Sx, Sy, SAngle);
SetObjectVariableInt(LNewObj, 101, 2);                              { ScaleMode: 1=None, 2=Symmetric, 3=Asymmetric }
SetObjectVariableReal(LNewObj, 102, ScaleFactor);
This is one of the things that seems random when learning vectorscript.
Some things are controlled with functions and some are controlled with ObjectVariable - Boolean/Handle/Int/LongInt/Point/Real/String
If you can't find it, just keep asking 🙂
An important thing to know about "LNewObj" is that it does not work as a handle; it is a function that returns (gets) a handle to the last created object.  It's value will change as soon as anything is created by the script.  If you are going to need a handle to a symbol for a variety of reasons, it is best to assign it to a variable and use the variable in all the different places you need it.
VAR
     SymbolName : STRING;
     SymbolHandle : HANDLE;
     X, Y, Rot : REAL;
     X1, Y1, X2, Y2 : REAL;
BEGIN
     Symbol(SymbolName, X, Y, Rot);
     GetBBox(SymbolHandle, X1, Y1, X2, Y2);
     Rect(X1, Y1, X2, Y2);
END;
