Dimension class visibility not toggling to show off
I need to make marketing drawings showing unit layout. One set of PDF drawings will need to show room dimensions and an identical set of PDF drawings will not show the dimensions.
I'm new, so this is an explanation of my workflow:
I've selected my viewport and click 'Edit Annotations'. I added my dimensions. I created a unique class name called "DIMS_unit". I select the dimension and in the OIP select the unique name from dropdown list. I then exit Viewport Annotations. If I want to export to PDF with no dimensions showing, I then go to the Navigation/Classes and turn visibility off for the unique dimension class name, but they are still showing.
What am I missing?
20 minutes ago, Jeff Prince said:
you need to select the viewport.
then look at the OIP (object info panel)., not your navigation panel.
Find the class button there and set it accordingly.
@Greg Rosenke-yes this is the likely culprit - I still every once in a while forget and have to 'oh yeah THAT class or layer' button.
