Hushaam Posted March 11, 2024 Share Posted March 11, 2024 Hello, we are trying to find a way with Pythenscript to Refrence VW-Worksheets a bit flexibel. We are having different Worksheets. We want to Refence one Worksheet with another Worksheet and trying to find out a way that Worksheetname for Reference can be flexible. At the moment with VW-Ref Function, the Worksheetname ist fixed and needs tobe changed if the Worksheetname has been updated. We also try to Run Python-Script in Vectorworks but not able to find out a way, how to retrive a PS result in a Worksheet. We are using this Function: =DATENBANKDURCHSCRIPT(120; 'Landschaft/Script.py') but unfortunately can not see what ist the output. We tried to find a Solution to List all our current Worksheet in some kind of Meta-Worksheet. The Python Script should iterate these objects and we would like to process the results within the RunScript Worksheet-Function but without success so far 😐: def list_all_tables(): # Eine leere Liste, um die Handles aller gefundenen Tabellen zu speichern table_handles = [] # Erste Objekt im Dokument h = vs.FActLayer() # Durch alle Objekte im Dokument iterieren while h != vs.Handle(0): # Überprüfen, ob das aktuelle Objekt eine Tabelle (Worksheet) ist if vs.GetTypeN(h) == 47: # 47 ist der Objekttyp für Worksheets in Vectorworks # Das Handle der Tabelle zur Liste hinzufügen table_handles.append(h) # Zum nächsten Objekt übergehen h = vs.NextObj(h) # Alle gefundenen Tabellenhandles an die Tabellenschnittstelle übergeben for id, h in enumerate(table_handles, start=1): vs.WSScript_AddHandleId(h, id) # Die Funktion aufrufen, um alle Tabellen aufzulisten list_all_tables() We would be very grateful for any tips or information 😃 Quote Link to comment
Pat Stanford Posted March 11, 2024 Share Posted March 11, 2024 I am a Vectorscript guy, not a Python guy, but your script looks ok to me. Do you get database subrows when you se the row criteria to be DatabaseByScript [DATENBANKDURCHSCRIPT]? Try putting the script in a script palette and remove the 120 from the start of the DATENBANKDURCHSCRIPT call. That way you can see if the problem is the script or the file location. Here are a couple of posts I have made about DatabaseByScript: Quote Link to comment
