Laura Stone Posted March 10, 2024 Share Posted March 10, 2024 I have some mesh objects a bit like hardscapes imported from Revit, unfortunately with a thickness, so levels are replicated on the underside. I think I know the answer to this, but is there any way of picking up the top surface only to get information for a site model? Laura Quote Link to comment
VIRTUALENVIRONS Posted March 10, 2024 Share Posted March 10, 2024 There are some ways. Each mesh is different. Post a file you are working with, small is good. Will have a look later. Quote Link to comment
Laura Stone Posted March 10, 2024 Author Share Posted March 10, 2024 That's very good of you. Hoping to avoid laboriously dropping a 3D locus onto each relevant vertice. Here's a file. Laura Surfaces.vwx Quote Link to comment
VIRTUALENVIRONS Posted March 10, 2024 Share Posted March 10, 2024 Hi. Well to start with, if you ungroup this file you will see it is several meshes or poly-surfaces. This changes things as far as a mesh, but may make your task easier.. So first ungroup the file. Then convert them all to 3D polygons. Ungroup the conversion, turn to a side view and Marquee select the top polygons. Hope this works out for you 1 Quote Link to comment
Laura Stone Posted March 10, 2024 Author Share Posted March 10, 2024 Thanks for that, that does work, bit tricky on the steep bits but preferable to the alternative! Laura 1 Quote Link to comment
